Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-03-2007, 10:37 AM
MikeSeq MikeSeq is offline
Programming Instructions for Remote
I just bought a replacement remote for my 93 Buick Park Ave Ultra, but it didn't come with instructions. Would appreciate any help with this.
Thanks.
Old 05-03-2007, 10:42 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Programming Instructions for Remote
For better visbility I moved your post to Park Avenue. Tips & Maintenance was just intended for the specific tech procedure.
Timeslip 08/12/06
AF Community Guidelines
Old 05-03-2007, 06:23 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Red face Re: Programming Instructions for Remote
Jump the (ALDL) Assembly Line Diagnostic Link. You will find this connector under the driver side dash, but you will have to look through a square cut out in the panel to see the connector, it is recessed behind that panel, almost directly under the steering column.
Jumper pin A to pin G with a fused jumper (3A)
Doors will lock and unlock
Press the UNLOCK button on the remote
Doors should lock and unlock again
if you have more remotes press their unlock button (up to 4)
remove jumper wire
________|________
[F] [E] [D] [C] [b] [A]
[G] [H] [J] [K] [L] [M]
Old 03-19-2008, 02:57 PM
ghalacsy ghalacsy is offline
Question about this. I have a 96 PA and it has OBDII with what looks like 16 pins. CAn i use the same procedure to program a remote to this car? BTW this remote is from a 97 PA.
Old 03-19-2008, 05:19 PM
HotZ28's Avatar
AF Moderator Elite
Welcome to AF. Please start a new thread with your question and link this thread in your new one, as a reference. Please read the link below:
Posting in Closed or Outdated Threads-PA
Closed Thread
