Old 05-03-2007, 10:25 AM
mitsu3kgt mitsu3kgt is offline
16g and stock internals
I am thinking of upgrading to evo 16g's. I just got done rebuilding my engine and it would be a waste of money to put new parts in it. So I would like to know if I would be okay putting 16g with my fresh stock engine?? Also did'nt Matt run his 9 sec. run on stock internals??
Old 05-03-2007, 10:42 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: 16g and stock internals
Yes matt did.. however matt has tunz and tunz of supporting modds... It all depends on what kind of engine management system you have.. It's all in the tune..
Old 05-03-2007, 10:49 AM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
wasn't like over 500 the crack or somthing likes to go out...
Old 05-03-2007, 11:49 AM
I was also looking at 19t's, because they are a lot cheaper than buying the td05 kit. What do everyone think about them?? Are they just as good as 16g or should I just spend the money on the evo turbos??
Old 05-03-2007, 12:19 PM
Igovert500's Avatar
blue + red light magnet
no td04 turbo is gonna compare to a td05. For the money the 19Ts are nice, (I think oohnoo hold the TD04 power record with them iirc) but if you can get ahold of adapter plates, it makes td05s alot cheaper. Regardless, it's just as easy to blow an engine with 19Ts as it is with 16Gs...as said above, it's all in the tune. The stock bottom end has been proven to do 700hp if the tune is right.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-03-2007, 06:18 PM
Where can I get a set of adapter plates from?? When I asked before people said that they were discontinued.
Old 05-03-2007, 09:26 PM
Igovert500's Avatar
They are. That's why I said 'if'
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-03-2007, 11:47 PM
Hotshot8792 Hotshot8792 is offline
somebody on 3SI started making the set i believe, but i've heart his wasn't as good as jpdc's were
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 05-04-2007, 07:20 PM
mygreenTT's Avatar
mygreenTT mygreenTT is offline
Send a message via AIM to mygreenTT
my vr4 is being fitted with 16g's right now, they were put on today actually. my motor has 111k on it with stock guts. it's going to be datalogged and tuned with an SAFCII at ~16 pounds with no problems. with your fresh motor it will love a set of 16g's. if you decide on the 16g's call jeff at IPS, i got the entire set up for 3 grand flat and i had them 4 days later.
93 3000GT VR4
blitz dsbc @ 1 bar
blitz turbo timer
autometer boost and a/f gauge on a pillar
greddy type s bov
NGK iridiums w/ NGK wires
3SX DP, 3" stainless single shot
drilled and slotted rotors w/ hawk pads, steel braided lines
supra pump hot wired
SPEC 3 clutch
PTE 550cc injectors
SAFC II
IPS tubular manifolds
evo3 16g snails
converted sidemounts courtesy of oohnoo
built and tuned by jeremy and keith at WSR
