Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-03-2007, 08:34 AM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
CV traction control system
Quoted from "Bruzilla's" site:
The CV's traction control system is designed to remove power from the car whenever a loss of traction is "sensed". Needless to say, these systems are far more sensitive than your typical driver's senses, and may remove power at times that the driver doesn't want it removed. The NLECTC recommended that drivers turn the traction control system off when optimum performance is desired, and turn it back on in situations where traction is vital (rainy and snowy weather).
My question:How do you turn it on/off? IE: where is this control on '99 CVPI ? THANKS
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Old 05-03-2007, 02:14 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: CV traction control system
Have you looked in the glove box?
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-03-2007, 11:51 PM
Just looked there, emptied the darn thing out and felt all around inside (I do my best work in the dark), didn't find anything like a switch or push button.
I did, however find my missing speed loader for the snubby, 2 cheap lighters, an expired insurance card from last fall, some WD-40, a Grafite pen, and 2 lbs of napkins!
Any other ideas? BTW, this IS a confirmed CVPI, not a wannbe.
Stale Trooper
'05 CVPI
Old 05-04-2007, 12:37 PM
Squid121 Squid121 is offline
The button on my '98 was in the glove compartment, behind the door but not in the actual compartment.
Old 05-04-2007, 07:45 PM
way2old's Avatar
TOKEN HILLBILLY
If it is a CVPI, it may not have a switch. Our 99"s do not have one.
Old 05-05-2007, 08:32 PM
03cvpi 03cvpi is offline
Most CVPI's will not have the switch. In 99 if it was ordered with electronic traction control the switch will be located behind the glove box door, but not in the glove box. It could also have been relocated to the trim panel just to the left of the steering column. Most CVPIs will not have it. They are usually built with traction lock limited slip differentials and do not require a switch. You would not really like it anyway, I have had it in a 200 and a 2004 LX and when I have to back up my driveway in the winter, the electronic unit will momentarily lock the slipping wheel to get the other one to grab, if this happens to many times in a fast sucession, the car will stall from vacuum loss. You can check the build sticker on the left front door and get the axle code from that and it will tell you if you have a limited slip, open type or open type w/traction control.
