Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 05-02-2007, 07:56 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Hood vibration help....PLEASE!
I have a 1996 eclipse gst with a little problem. I have solid motor mounts. They are prothane motor mounts that make a lot of vibration. Here is the problem I need some help with. Since there is an excessive amount of vibration due to the mounts, my hood vibrates a lot!! Is there a way to deaden the vibration on the hood by adding something (ie: rubber in between the latch and hood insert...)? It is to the point that I can hear the hood vibrating from inside the car while idling.
Any ideas?
Let me know
Thanks
Ben
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 05-02-2007, 09:07 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Hood vibration help....PLEASE!
Yea I get that sometimes also. Its incredably loud and annoying. Im not sure how to fix it yet.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-02-2007, 09:23 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I've got that all the time.
-First, adjust the little rubber stoppers on the front of the car above the headlights. Those IIRC are for the most part, unscrewed as far out as they can go.
-I then went to Ace Hardware, and bought some little rubber feet with double sided tape on them. They're actually kinda like foam almost. I put those along the top, close to the windsheild, so that the top of the hood, is now solid with the plastic part in front of the windsheild. Mine doesn't rattle at all now.
And yes, I do have the engine mounts also.
I'm actually in the process of rattle-proofing my car... calling it Operation Rattler. Sexy name IMO.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-03-2007, 11:52 AM
JScharF JScharF is offline
whats IIRC mean by the way?
1995 Mitsubishi Eclipse GS
Old 05-03-2007, 01:17 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
If I Remember Correctly
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-03-2007, 04:23 PM
mtcs's Avatar
problem fixed
thanks for the help everyone!
1996 ECLIPSE GST
Old 05-03-2007, 06:19 PM
Holset powered 420a
So are you going to let us know how you fixed it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-04-2007, 09:45 PM
mtcs's Avatar
Used something like this
Just used some silicone rubber sealant and glued it to the other rubber pieces...works perfectly...no more rattle!
1996 ECLIPSE GST
