60k?
for you guys that have done a 60k...did you pull the radiator? The walkthrough i looked at on vr4stealth.com recommended it, but it seems like overkill to me.
also, anyone have a timing tensioner pulley tool i can buy/rent/borrow? home made worked for the cam lockers, but i dont think i can make this one. I would just buy one, but the fact that 3sx wants $20 seems rediculous...and that they wanted $12 for shipping just F****** pissed me off... i dont really think people in the 3/s community should rip each other off like that. we have enough adversity to overcome. |
Re: 60k?
Screw the tensioner tool. I have never used one. As for the rad you should be able to get by by just removing the rad fan. It gives you better clearance to remove the altenator.
Re: 60k?
<--- didn't use a tensioner tool. Instead I used a wrench to hold the pulley in place while tightening it.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: 60k?
Re: 60k?
Re: 60k?
3SX rips you off every chance they get. don't support their business practice by purchasing anything from them.
i've used allen wrenches in the tensioner pulley holes, then rotate it with a screwdriver. but i recommend the tensiner pulley tool made by Schley Prodcuts (more info here). you can get it for $16 shipped, GREAT design, and much more durable than the 3SX tool that breaks all the time.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: 60k?
^ kickass man. thanks.
Re: 60k?
somebody on 3SI sells one pretty cheap too. I've heard good things about it.
Re: 60k?
yea i saw that one too. similar in design to the 3sx one, but $10.
anyways...ive ran into a problem. Just when im feeling like im making some progress, too. I'll skip making a new thread becasue it still falls under this subject. I cant get the freaking crank pully off. From what ive read, most impact guns aren't strong enough, so i skipped trying one and went right to the bump the starter method. So...what if thats not strong enough either? I even tried it with a jump box hooked up to the battery for a little extra kick. Im gonna have my dad bring his impact over and give it a shot, only becasue im out of ideas. anyone have any advice? |
Re: 60k?
the bump start method ALWAYS works.
Re: 60k?
not ball-busting bro...it didnt. Tried it 5 times. 2 on strait battery, 3 with the jump box. No dice.
ive got it spoojed with wd-40 right now and ill try it again in the morining. |
Re: 60k?
that's odd. i bet it didn't work because you've NEVER had the crank pulley off before AND the bolt is much tighter than spec. but decent impact wrench should have no problem removing the bolt.
Re: 60k?
that means 90k on the original timing belt ><
ill count myself lucky i guess lol. |
