Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-02-2007, 02:07 PM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
Tan wire w/black stripe???
Does someone have a pic of the tan wire w/black stripe that you disconnect when you check timing? I've looked for it on the '89 camaro and can't find it. I've also looked for it before on my '97 silverado and on my dad's '89 silverado and have never been able to find it. It's got to be there somewhere.
Thanks,
Rob
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 05-02-2007, 06:01 PM
Morley Morley is offline
Re: Tan wire w/black stripe???
The wire is either back by the firewall on the passenger side. It comes up out of the big wire loom, has a single pin connector on it and then goes back into the loom.
Or it is by the passenger fender, near the strut tower. Same wire with a single pin connector. They say it is tan/black but it is closer to brown/black.
Old 05-03-2007, 02:05 PM
rob67gmc's Avatar
Found it. More brown than tan, next to the strut tower. Timing is at about 9*. What should it be set at?
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 05-03-2007, 09:59 PM
Timing should be 6* BTDC in drive, parking brake on and wheels blocked....resist the temptation to rev the engine while doing the timing check until AFTER you get done and put it back in park.
Old 05-03-2007, 11:48 PM
rob67gmc's Avatar
Can't put it in drive since it is a 6-speed. Should it still be at 6* BTDC in neutral? I just read in a book that it should be between 8*-12* BTDC on a TPI engine, but you haven't steered me wrong yet.
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 05-04-2007, 10:10 AM
Yep, put it in neutral on a manual. I don't know who would print it up as 8-12* but that can cause detonation. The "base" timing is programmed into the PROM chip, meaning that the ECM "knows" that it is starting from 6* and from there uses its timing tables. Now, if the timing were set to 12* then the entire timing table would be skewed to the high side by 6*. Running that much timing can and will cause detonation problems in several places throughout the spark curve. If you have a scanner that can data log you could try advancing it 2* from factory, take it out for a run and see what the data logs look like. You could keep doing this until your knock counts go up. Then back it off the last 2* increase you did and 2* more for safety (hotter weather, lower octane gas, etc).
Old 05-06-2007, 12:56 PM
rob67gmc's Avatar
Set the timing at 6* and drove it for about 30 miles. I think it it needs to be tweaked a little. Engine lugs a little when you start off.
What would be a good but not too expensive scanner or would it be better to use a laptop?
I got the 8-12* timing info from the book "How To Tune & Modify Your Camaro 1982-1998". It said "1985-1992 TPI cars generally respond well to base timing of 8-12* BTDC".
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 05-06-2007, 02:18 PM
The "best" scanner would be a laptop. The cable can be made for about $4, the scanning program is free and laptops can be found for $50 on E bay.
If you want/need the schematics for the cable and want the program, let me know and I'll E mail them to you.
Old 06-07-2007, 03:53 PM
chadis's Avatar
chadis chadis is offline
i have a 1987 irocz was wondering what this scanner u speak of is all about???
