Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 05-02-2007, 01:52 PM
Roy_Nacky Roy_Nacky is offline
Question Help Please
My Kia had the Check Engine light On But it was working okay now it started to give me a little trouble
1.When I am going out an intersection and I try to give it gas it tends not to have any strenght or it cuts off.
2.Now Couple days ago I was going to pickup my kids from school but I had to make a quick stop, and when I got Back it wont start.
I got a code reading and these are the codes I got P0172,P0101,and P0123.
Can anyone give some HELP PLEASE
Old 05-02-2007, 08:19 PM
LMP's Avatar
LMP LMP is offline
Re: Help Please
101 Mass air flow
123 Throttle position High input
172 Mixture rich
...172 probably consequence of others.
P0101 Mass air flow circuit range/performance problem
Related Items
Dirty air cleaner.
Oil Cap or Dipstick missing or not installed correctly.
Air leak in intake system.
Contaminated, deteriorated or damaged MAFS.
Faulty MAFS or Throttle Position Sensor (TPS).
Poor connection(s) (or high resistance in wiring) between ECM and MAFS or TPS.
P0123 Throttle position sensor circuit high input
Related Items
Open or short to battery between Throttle Position Sensor (TPS) C144-3 and (ECM) C211-73.
Open between (TPS) C144-1 and (ECM) C211-71.
Faulty TPS.
P0172 System too rich
Related Items
Faulty ignition system.
Faulty fuel delivery system.
Faulty fuel injector(s).
Faulty Front O2 Sensor.
Faulty Mass Air Flow Sensor.
Faulty Throttle Position Sensor.
If any codes relating to injectors, O2 Sensor, Coolant Temperature Sensor or Mass Air Flow Sensor are stored, do ALL REPAIRS associated with those codes before proceeding with this troubleshooting tree.
.. at first do not jump to conclusion of changing all items related to codes. Corrosion at sensor plugs is common.
But let us have some more info, year, mileage, any repairs done before, previous troubles....some problems can have different meaning depending on age and mileage. FOr how long did you have the CEL ON? DO you have a scanner or had the codes read elsewhere? Were the codes cleared ? DId they come back and in what sequence?
CHecks threads in this forum about IAC (Idle AIr COntrol valve) , CKPS (Crank Position Sensor)
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
