Old 05-02-2007, 12:36 PM
Brass_GA Brass_GA is offline
ICM / Coil Packs
I have a friend that just lost his ICM. I have access to a module and coils from a 3100. His is a 3400.
Would the module and packs be a suitable replacement?
Old 05-02-2007, 01:56 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: ICM / Coil Packs
What years!!
The 98 3.1 coils and ICM are the same part # as a 2000 3.4.
ICM # 10489422 and the coils # 10472401
So yes it should work, if the plug on the ICM is different then obviously it wont work.
Hope that helps!
1999 Grand Am SS 3.4 OHV
Old 05-02-2007, 03:59 PM
Would the pin configuration on the plugs the same? Assuming they fit.
Old 05-02-2007, 06:00 PM
should be they are the same through most of the newr 3.1 & 3.4's -05'.
Old 05-02-2007, 07:14 PM
They were the same. I had it switched out in under an hour. I don't think it helped our problem though.
Thanks for the input.
Old 05-02-2007, 07:26 PM
check the fuses and the wiring.
Also make sure no pins in the ICM plug are bent or broken
Old 05-03-2007, 07:07 AM
The pins are fine but we didn't have time to unwrap the wires. The car still runs. I haven't looked at the fuses yet but I assume there is one for each coil or cylinder.
