Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-01-2007, 11:41 PM
20zetechzscort 20zetechzscort is offline
Question advice
hey guys , i just bought a 98 talon AWD, it has about 120 k on it, this is my first turbo charged car, and i have NO idea where to begin with it. im working with about 2 grand to fix it up, any advice on where i should start... and hopefully no one says a engine rebuild. o and around what mileage does the timing like to go out on thease cars ? thanks for ANY help guys
dan
1998 ford zx2:
bomz cold air intake
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-01-2007, 11:47 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: advice
I would probably suggest you take a look at the condition of the T belt and if it looks worn at all, replace it. All the other general maintenace like tranny fluid and coolant flush, replace the fuel filter, maybe the spark plugs and wires if they look worn, etc. Get it running at optimum level, then maybe look at some basic bolt on mods if your wanting a little more power.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-01-2007, 11:53 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: advice
Like _eclipse_ said, give the car a general tune up. Plugs (ngk's), wires, fuel and air filters, coolant flush...things like that. Also look into the timing belt. We're supposed to replace ours RELIGIOUSLY at 60-70k miles, and at the 120k mark you're looking at doing the second timing belt job. They're not *hard* to do at all, they just take some patience and knowledge. If you're good with your hands and cars, you should be able to pull it off no problem, just make sure you do some reading first and ask ANY questions you have. A messed up timing belt job could end you up with a bunch of bent valves, or even worse a whole engine that's wrecked. Then check into some general mods like some hard intercooler pipes, manual boost controller, BOV, and an upgraded exhaust.
dsmtuners.com also has a great upgrade path, check it out. http://www.dsmtuners.com/sub.php?page=2gtstage0power
95 Talon TSI AWD
97 Eclipse GST
Old 05-02-2007, 12:09 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: advice
Couldnt have said it better myself. Do a little bit of research and find out what ur goals are for the car. Then do a lot more research. Ive been on here for 9 months or so, and have been helped through every step along the way. From my turbo intake making a whistling sound to what intercooler to buy. Check the upgrade path like GT said, it is basically what i did step after step. I started out with a boost gauge, turbo intake, BOV, MBC and a 3 inch exhaust as my first purchases.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 05-02-2007, 01:42 PM
Re: advice
thanks a bunch guys...whats the easy way to just check the t belt? o i was going to get a hyines manual..i know thats not how u spell it. just so i can see how everything comes off...this car has been sitting for about 7 months and its a older fella that im getting it off of. it needs eather the filter or fuel pump and i get to take it for $1300.. the body is in great shape..its going to be a hella upgrade from my little ford escort zx2.....well as far as what path i wanna go with this car for the moment...the car is gonna be my daily driver and im gonna have the zx2 as my back up car...and i know the car as it sits 100% stock and shits and gets as it is but i wanna be sure that no lil honda gets me at a green light...i kinda wanna make it a sleeper. so im not going to do a body kit.. maybe a front bumper just to hide the innercooler if i get/ need one.. i was looking at some of the sites that are in the stickys and are they all good and trustworthy? im not a fab. man so i dont wanna get a lota parts that need to be fabed. overall i would like to see about 250 to 300 hp and as i said im working with about 2 grand or so....thanks again guys
Dan
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-02-2007, 01:50 PM
Re: advice
o one more thing it is a 5 speed..i dont know if a 98 AWD's are or not . like i said i dont know much about this car.
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-02-2007, 02:23 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: advice
If it were my car, I would replace the timing belt if I didn't know the service history. If you can do the work yourself, the parts will run around $325. Other than that, everyone is correct. Plugs, wires, fuel filter, coolant, oil, trans fluid, brake fluid, clutch fluid, etc.
I'm confused by your last post?? In your first post, you stated that the car is a Talon AWD, but in your last post you asked if 98's are AWD???
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-02-2007, 03:08 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: advice
options on both 5-speed and auto... hope for you its a 5-speed...
Old 05-02-2007, 03:11 PM
Re: advice
no i was asking if if 98 AWD all were 5 speeds .... cause that is what my car is thank god..im tired of auto trans lol
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-02-2007, 03:15 PM
Re: advice
yeah i am planning on doing a FULL tune up..t belt fulsh EVERY thing..it has new plugs and wires i dont know what brand off hand..im going to get the car this weekend...where or should i say what site is like a one stop shop for this stuff ? ( t belt set...fluids.that sort of stuff)
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-02-2007, 03:18 PM
Black99GST's Avatar
Re: advice
i told you it was an option, you could have either auto, or a 5-speed
Old 05-02-2007, 05:05 PM
Re: advice
98 TSI AWD = sexies DSM in production. You're getting a VERY, VERY good deal on one hella sexy car, I only wish I could be that lucky.
For the parts on the timing belt, you can get them pretty much everywhere.
extrememotorsports.com
slowboyracing.com
magnusmotorsports.com
roadraceengineering.com
All of those sites should have the parts that you need, just do some shopping around to find which ones you can get cheaper. Also I suggest going with the balance shaft eliminator kit, it's a fairly simple modification and eliminates the need for that pesty balance shaft belt.
95 Talon TSI AWD
97 Eclipse GST
Old 05-02-2007, 05:22 PM
steviek's Avatar
steviek steviek is offline
Re: advice
yea dude you just lucked out big time I'm kinda jealous. When I bought my TSI AWD a very long time ago it cost me 11500 CDN. these guys got the right idea on what to do first just listen to em all they know their stuff.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-02-2007, 05:43 PM
Re: advice
thanks for all the help guys ..ill be keeping u all posted on my progress and asking hella more questions..... ok i gotta ask what is the balance shaft? pros and cons of keeping it or getting rid of it ..and what is involved in taking it off...im guessing its right there when i do the t belt.
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-02-2007, 06:00 PM
steviek's Avatar
Re: advice
http://www.automotiveforums.com/vbul...+shaft+removal
seek and you shall find
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
