Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 05-01-2007, 11:06 PM
Andrewhuffman Andrewhuffman is offline
intake
1991 300zx 3.0 twin cam, non turbo.
it has the two intakes into a ''Y'' pipe, couldn't, i just seperate it an put two filters on it? also how does it keep from sucking up water if it just sits in the front like it does.
GT2560r's, Nismo 615cc, ARP Head Studs, UD Pulley, SouthBend Stage5 clutch, 60mm TB's, Ash-spec Tune, Specialty Z 3" DPs, HKS intake,
Energy Suspension, z1 Drive Shaft,E-fan, Port/Polished heads, AMS Manifolds, HKS SSQV BOVs, Howe Radiator, RPS segmented LW flywheel, UR OverDrive waterpump pulley, Billion Thermo, z1 silicone hoses, Stillen gauge pod w/autometers, D&S rotors all around
Old 05-01-2007, 11:31 PM
robzone0911 robzone0911 is offline
Re: intake
You would need to buy a second MAF to do that, and those retail for, correct me if I'm wrong, around $500 from Z1; however, you could probably get one (unknown condition) off ebay for less than $200. Normally there is a splash guard underneath the front facia that keeps water away from the intake.
If you did decide to add a second MAF and make a dual intake, you would need to splice into the existing lines for the MAF connector, and even still I'm not sure how well it would work.
1...2...3...go! 16.3@85mph 2001 Cavalier Z24 Happily traded for my Z32
Old 05-02-2007, 01:06 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: intake
short answer: no, you can't... if you have to ask, you can't
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 05-02-2007, 05:45 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Re: intake
It's easily done, look up any dual intake kit made by one of many companies. However this has to be corrected at the ECU, as the MAF is now only reading half the air coming into the motor so it's not as simple as just new pipes and a second filter.
You don't technically need a second MAF, it just means you're probably going to have a persistent idle problem if you don't. Also, working MAFs can be had for $100.
However, for a non-turbo motor you're just not flowing enough air to make the mod worth it. Even on a mildly modded twin turbo (say around 300rwhp) the gain from a dual intake is about 10 hp over a single. For a NA that's not pulling nearly as much air the difference is going to be negligible.
It sits high enough off the ground and tucked up far enough that it's not an issue. Hell it does get wet, after driving in an "ocean falling from the sky" down pour I noted my filters were soaked. However this failed to cause any problems. To hydrolock a motor you usually have to have the filters partially submerged or subjected to a massive dose of water (like a large splash of water driving through a puddle).
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
