Old 05-01-2007, 05:56 PM
gamitchss1 gamitchss1 is offline
A/C won't switch from floor to vents
My 98 Grand Prix GT is having a problem with the vents. It won't switch from floor to the vents. Is there a door in the A/C/Heater unit? Is it electrically controlled or vacum controlled?
Thanks,
GM
Old 05-01-2007, 08:01 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: A/C won't switch from floor to vents
Welcome to AF.
The actuators are both vacuum and electrical. Check the accessory vacuum line from the back of the upper intake manifold along the firewall and where it loops by the battery/main fuse box and into the main wiring harness that goes into the firewall and HVAC. Low or no vacuum will cause airflow and vent problems.
Timeslip 08/12/06
AF Community Guidelines
Old 05-02-2007, 07:45 PM
Thanks for the reply. I found the vacum line on the back of the manifold, followed it to the a fitting behind the battery. The fitting is cracked. There is one line atached. I think there is a second line supposed to be attached to the fitting. I'll have to pull the battery to find the second vacum line. And make a trip to the Pontiac place for a new fitting.
Thanks for the advice.
GM
Old 05-03-2007, 05:55 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
You could just buy a short piece of rubber vacuum hose that fits snugly over the hard plastic line and repair it that way. I would bet the GM factory parts are $$$.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-03-2007, 08:40 AM
I'll probably do that. I'll make a trip to NAPA for some vacuum hose and a T.
Thanks,
GM
