Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 05-01-2007, 04:53 PM
tri-power's Avatar
tri-power tri-power is offline
Trouble Code
Would a loose fuel cap cause code P0456?
Old 05-02-2007, 11:32 PM
American645 American645 is offline
Re: Trouble Code
How Did You find your code? & Whats the procedure?.
Sincerely
Fustrated 2004 durango owner.
Old 05-03-2007, 12:31 AM
tri-power's Avatar
Re: Trouble Code
I didn't get it. It's my neighbors truck. I had him go to Advance Auto and borrow their scanner. He left his gas cap loose a couple days ago and the check engine light came on.
Old 05-21-2007, 08:05 PM
PICKUP6772's Avatar
PICKUP6772 PICKUP6772 is offline
Send a message via AIM to PICKUP6772 Send a message via MSN to PICKUP6772 Send a message via Yahoo to PICKUP6772
Re: Trouble Code
Straight answer. Yes, the fuel cap will pull a P0456 code. It is showing that there is a leak in the EVAP system.Almost any vehicle from 1996, and up with the OBDII system will show a code with the fuel cap loose, or missing.
Mike
Old 05-23-2007, 08:41 PM
tch1717 tch1717 is offline
Re: Trouble Code
yeah P0456 is a small leak detected in the emmision system, no big deal, fuel cap could cause it, depending on the year of the durango, if it's a 4.7L also check around the purge solenoid and the rubber hose coming from the intake plenum, they have a tendancy to crack when they get a little older...i know, i fix them all day long !!lol...there is also a small "elbow" under the truck (about right under the drivers seat) at the leak detection pump tha is common to crack causing the code
