Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 05-01-2007, 04:14 PM
cbrooks5 cbrooks5 is offline
Unhappy 1991 wont start
I installed a new starter and still get a click sound and nothing else. there is click somewhere under the hood besides the one coming from the solenoid. new battery new starter, still same ole problem, are there relays for this? besides the one next to the battery??
Old 05-01-2007, 04:27 PM
GBH1's Avatar
GBH1 GBH1 is offline
Re: 1991 wont start
take out your switch, and check the wires.
Not I - I won't conform to what I see in you, Not I - I won't surrender what I am, Not I - And even if it was a part of me, Not I - I'll never be that way again- Demon Hunter
Old 05-01-2007, 04:30 PM
Re: 1991 wont start
which switch?
Old 05-02-2007, 02:02 PM
jdl jdl is offline
Re: 1991 wont start
You might do some testing at the starter relay. Do you have a power distribution center under the hood? The relay should be located there.
You might be able to start it, make sure the tranny is in neutral or park, set the e-brake. Remove the relay, Turn the key on, use a jumper wire, between terminals 30 and 87. The starter should crank, if it starts, remove the jumper.
You'll have to do some testing, that 30 terminal should be hot all the time. What engine size?
Old 05-03-2007, 01:05 PM
GBH1's Avatar
Re: 1991 wont start
Originally Posted by cbrooks5
which switch?
the ignition switch.
