Old 05-01-2007, 03:53 PM
justinWants2know justinWants2know is offline
Send a message via ICQ to justinWants2know Send a message via AIM to justinWants2know
Question 99 Lumina Break Issues
Some conflict with the bottom brakes no working. Seems to work when the TURN SIGNAL FUSE is pulled out.. Is there a short going on? Is the fuse box malfunctioning? HELP ANYONE
Old 05-01-2007, 05:40 PM
Artem F Artem F is offline
Re: 99 Lumina Break Issues
imho, it's the turn switch. The upper brake light is wired directly to the brake switch. The lower ones go through the turn switch because the same bulbs are used both for brakes and for turns and one has to cope with it somehow when the car brakes and turns simultaneously. Does it help if you move the turn switch rod up-down-left-right-forward-brackwards a little? If it does then the turn switch definitely needs replacement ($60 plus one has to borrow two pullers, one for the wheel, one for the wheel plate or how is it called)
Old 03-12-2008, 08:45 AM
irish lassie irish lassie is offline
i just had this repair on my '93. all works fine except yesterday i noticed that my signal is not canceling after my turn is made. just a fluke or maybe an installation problem.
Old 03-12-2008, 09:05 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Plastic cancel cam got broke...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
