Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-01-2007, 03:38 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
still whistlin.
its like a old man on crack who has a broken front tooth and a harmonica.
anyway. its still friggin loud, i still havent narrowed it down..and im lost-er than ever.
on a side note, i run full synthetic mobil1, and i noticed the oil is getting a LOT dirtier than normal..
suggests intake leak?
so..no one answered my lastquestion.
could vaccum tube leaks be so loud that it can be heard from inside the car w. the windows up? or with the windows down, going 50-6o on the freeway?
if it cant.. then its somewhere in my tb..
how about the air-foil. can that make lots of noises?
it gets QUIET at certain THROTTLE position
not rpms. i could be going 4K rpm, with real little throttle..and id still hear it..
or i could be going 2Krpm, with half throttle and you wont hear it.
suggests intake, right?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 05-01-2007, 04:00 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: still whistlin.
If that's the case, it has to be a manifold vacuum leak. Remember, when accelerating, manifold vacuum is reduced to near nill (ported vacuum increases) , so that would have to back that theroy up a bit. I worked on a v6 one time with a similar prob but sounded like a damned harrier jet setting up for take off. Ended up being the EGR pick gasket.
Old 05-01-2007, 05:39 PM
Re: still whistlin.
haha thanks, so that basically means i gotta figure out where its leakin from right.. god, i gotta try that cool trick i saw on CSI.. blow smoke on it but eh. new intake manifold gasket?
Car:
285's in the back
all else = STOCK.
Old 05-01-2007, 05:49 PM
goldz28's Avatar
goldz28 goldz28 is offline
Re: still whistlin.
check the hoses to before you go replacing a gasket. Get a friend to push on the throttle so you can hear it. Go to a auto store and get one of the Autostethoscopes so you can try to pin point the noise better.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 05-02-2007, 08:27 AM
wrightz28's Avatar
Re: still whistlin.
It has to be a huge hose/leak. Did you do anything to the car before this all got started?
Old 05-02-2007, 03:49 PM
Re: still whistlin.
yeah.. i was actually messing with the front of intake manifold..i took off the front part cuz i was changing my IAC..
Car:
285's in the back
all else = STOCK.
