Old 05-01-2007, 11:03 AM
Brians91ef Brians91ef is offline
Need Help b16 obdo
Can anyone help me i have a b16 in my 91 ef and it just cut off on me one day and it wont start i had people check the timing and they said it was on bought another ecu and still nothing the car has 150 psi in one cylinder and 200 psi of compression in the others so i know thats fine when i try to start the car it just repeatedly backfires and doesnt make an attemp to start. I pulled the fuel line that runs from the injectors to see if it'd spray fuel and it did i dunno wat the problem is please give any advise its greatly appreciated!!!!!!!
Old 05-01-2007, 11:49 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Need Help b16 obdo
Check for spark. An intermittent failure like that sounds like either your coil of ignitor went bad. Since you said your timing is good and your getting fuel, spark would be your next check.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 05-01-2007, 01:52 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
check your wires sounds like you mixed them up. that's unusual pressure too. you might have a bad ring.
-tony-
2000 honda s2000
Old 05-02-2007, 10:47 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
150 and 200. thats a big comp difference. there should not be more than a 20psi difference between each cylinders. do a leak down test to pinpoint the problem. 150 psi and 200 psi. you need to rebuild or get a new motor.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
