AC making rattle noise
Hey all
I noticed recently that when my ac is on, theres a rattle from under the hood. It goes away as soon as i turn it off, and comes back as soon as i turn it on. Suggestions? (edit: Forgot to mention, 98 intrigue, 95k miles) |
Re: AC making rattle noise
Just a quick bump, only time ill bump this thread before moving on to a real mechanic shop
Sounds like a clutch bearing problem on the AC compressor. Rockauto has the bearings and the clutch priced pretty well. $20 for the bearings and $40 for the clutch. I think you could do this repair yourself if you had the time and tools.
Mine used to do this. The noise would vary with RPMS. Then the A/C quit working altogether. All it needed was a recharging and it worked great and had no noise. Now it doesn't work again, but that's an unrelated issue.
How about the reverse of theis. I get a metal on metal noise off and on but I make it go away each time I turn on the A/C or Defroster and this has been about 2 months. Same A/C compressor bearings & clutch problem? And is it a repair where the compressor does not have to be removed or replaced?
TIA
haha mine does exactly the same thing, I would think it could be the same problem, I havent messed with it, because my AC still works, and the noise eventually goes away.
2000 Oldsmobile Intrigue 3.5 DOHC V6 Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners 1986 Jeep Cherokee 2.8 V6 |
