Old 04-30-2007, 10:16 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
Turbo Question
I have a TD04 off a Conquest/Starion and I am planning on putting it on my car here pretty quick. My friend has a 1998 Eclipse GS, and just bought a Hahn Racecraft Turbo and Manifold used off ebay. We are planning on doing this project together. My big question is of course...what ALL is needed. The most obvious parts are the turbo itself, which i already have, and a manifold. Then the charge pipes, a downpipe, and and intercooler, although its not necessary. What do I need as far as an oil pump, lines, and any fuel pressure/oil pressure regulators and such go? I am trying to keep a $500-$600 budget. What are the necessities just to get it going. I dont need a boost timer, and all the gauges and such, just simply a decent homemade turbo setup. I have been to www.homemadeturbo.com as well for a few resources.
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 04-30-2007, 10:26 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Turbo Question
Well, for a $500-$600 budget you are going to be cutting it close. You shouldn't need a new oil pump or fuel pressure regulator. But the rest of the parts you will need. You'll also need some kind of ecu chip and upgraded injectors. You will need an oil line to feed oil to the turbo as well as one going from the turbo down to the oil pan. Some turbos have coolant lines as well, but it's not necessary to run them, but it does help for longevity of your turbo. I would recommend at least a boost gauge, oil pressure and air 2 fuel gauges - they well help you a lot with your tuning and to help you know if anything is going wrong with your setup. I'd also recommend a new clutch so you don't burn up your stock one really quick. I think I got everything except the BOV. But you have the right idea - keep reading up on them and you'll probably find a couple other things to do. Oh I would HIGHLY recommend ARP head studs - those will save your headgasket from blowing too quick.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 04-30-2007, 11:06 PM
Re: Turbo Question
what do i do about getting the oil TO the turbo and recirculating it? do i need an in line oil pump or something? and what about boost? how do i know/adjust the boost? wastegaste spring? i think the td04 is set stock at like 6 psi. i should be ok on stock internals on that, correct? i dont gear band it really. i take it pretty easy. i dont race on a regular basis.
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 04-30-2007, 11:17 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: Turbo Question
and a 4g4d store would probably be different routes and prices of turbo set ups. hes probably got a few hundred into it thus far and ive got almsot 2 grand in mine. its jsut a brand and product war.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 05-01-2007, 04:05 PM
4G4D Store's Avatar
Re: Turbo Question
You don't need an inline oil pump - most people tap into the back of the motor where your stock oil pressure sender is and put a "T" in it and run a line up to the turbo, then the turbo return line just dumps into the oil pan. As far as boost goes, as long as your bottom end is good and you have it tuned correctly you should be able to do up to 11psi without any problems. But you'll be fine with the stock wastegate setting which is usually around the 6-8psi.
Old 05-02-2007, 10:43 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Turbo Question
http://www.beesandgoats.com/boostfaq/g2icturbo.html
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 05-02-2007, 10:40 PM
Re: Turbo Question
What about bigger injectors? Necessary? And is there a place that sells turbo kits as cheap as they do on ebay. I might as well just start new. I dont even know if the turbo I have sitting in my garage works. A friend gave me it about a year ago.
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 05-03-2007, 03:50 PM
4G4D Store's Avatar
Re: Turbo Question
Yes, you will need bigger injectors, and no, ebay is the cheapest for complete kits, but I'd recommend against them. I've heard they are hit and miss - you may get a good one, or you may get a bad one. Tough to say.
Old 05-03-2007, 04:07 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Turbo Question
homemadeturbo.com will definately help you out a lot....
-Turbo
-Manifold
-Downpipe/exhaust
-wastegate (unless the turbo is internally gated, which i'm sure it is...)
-BOV
-Charge piping/couplers
-intercooler
-oil lines (www.stealthmodeperformance.com)
-DSM 440cc injectors
-tuning system/tuning
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
