Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 04-30-2007, 07:42 PM
bluezuan bluezuan is offline
I've got problem----Anyone know about Tap and dye
I feel kinda stupid. I was placing a tempature sending gauge switch in my 94 ram... the stem as you know goes into the threaded hole. As I was tightening it the bolt broke off and now I have a brass or soft metal stem shaft in the hole. Can I get this out? Can I just buy the tap individually? It broke off right at the surface. Will a tap handle this problem? Help......
Old 04-30-2007, 10:10 PM
alloro alloro is offline
Re: I've got problem----Anyone know about Tap and dye
Get yourself an easy out extractor set. These are reverse threaded, so all you do is drill a hole and wrench one of these into the hole and the broken piece should come out.
http://www.nationalwholesaletools.co...tor-)-Set.HTML
or:
http://www.mytoolstore.com/hanson/extractr.html
Old 05-01-2007, 05:38 AM
or:
Much gratitude on the info...
Old 05-01-2007, 10:17 AM
I got the extractor set and it worked like a charm-----thanks for all the info...
Old 05-01-2007, 08:22 PM
Ahh good, it's the simple things in life.
