Old 10-17-2002, 08:30 PM
Smyrnan782 Smyrnan782 is offline
Quick Question
When bridging an amp, do the ohms halve like they do when you wire them in parallel? Another quick one; can you wire two subs in parallel on a bridged channel?
Old 10-17-2002, 10:48 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
on most amps, you can run either 2 or 4 ohm before bridge, but once you bridge MOST amps will only run 4 ohm.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 10-18-2002, 05:26 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
just remeber.... bridging halves the impedance each amp half "sees" - so if you bridge an amp and put a 4 ohm load on it (total), each of the amps (left and right) only effectivley sees 2 ohms.
Old 10-20-2002, 10:29 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Oh geesh, I know we would get into the "ohms" question as soon as I read the title...
Alright, a NORMAL 2 channel amp you can run it the following ways...
2 channels x 4 ohms
2 channels x 2 ohms
1 channel x 4 ohms bridged
So if you have TWO dual 4 ohm subwoofers you could either run them (2 channels x 2 ohms) or (1 channel x 4 ohms bridged) but you couldnt just throw them all on the same line to get a 1 ohm load, since most likely you will toast them amp - that is unless its like a mono channel amp which would be able to take this sort of load.
Dont worry about all the DETAILS to what an amp "sees" etc. Its pretty useless to consumers...
AF's Official Asshole
RIP AUNIE
Old 10-20-2002, 04:43 PM
Audio Guy
sometimes I wonder .... I know I knew NOTHING when I started making speakers at like 12 or so. I think that either you need to learn this stuff (ohms and bridging and the stuff) if you really want to do this stuff, especially if you want to do it RIGHT. It just never ceases to amaze me, a guy puts a post - aight, I got an amp, now where do the wires go .......... If it's not pretty intuitive after reading the installation manual, you should seriously consider getting someone to do it for you - that way us DIYers won't keep getting a bad name.
