Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-30-2007, 06:25 PM
rs_green_machine's Avatar
rs_green_machine rs_green_machine is offline
Send a message via Yahoo to rs_green_machine
Unhappy Power Doors Problem
hi guys
i have a 95 rs non power and got a good deal on some 98 gs power doors.. my problem is that when i plug them into the chassis harness they dont work at all ..is there somthing im missing here? because when i looked at the plugs all the prongs are there so i figured it should be plug and play.. is there somthing else i have to do for them to work....
thanks
Old 04-30-2007, 06:38 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Power Doors Problem
I don't think they're plug-n-play, I think you need some other wiring from the GS besides just the doors.
95 Talon TSI AWD
97 Eclipse GST
Old 04-30-2007, 06:50 PM
thats what i was wondering but like what wiring ? and why would all the prongs be there if its not ment to work?
Old 04-30-2007, 09:26 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
The only other wiring I can see you needing is however the doors are powered. You would probabaly need to run a power wire into the fuse box under the drivers side dash (Pretty sure it's int he same place as on the turbos) Those are the fuses for the interior electronics.
1991 GSX 2.3 Stroker
Old 04-30-2007, 10:06 PM
yeah, my fuse box cover says theres a fuse for the doors ,so i checked it and there is a good one in place,,,,do you think its there just for looks and no wires are actually ran?
Old 05-01-2007, 07:05 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
That's a good question. Normally you will find the wiring in place for the accessories, but you don't find a fuse. Most of the time, they install the wiring but don't feed it power, as defiancy said.
Check the fuse box and make sure the wires are actually hooked up. You might also what to get ahold of a wiring diagram.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-01-2007, 07:23 PM
ok so check it for wiring , and if there isnt any can i run one from the battery to the fuse box and if i do that it should run both sides right?
Old 05-02-2007, 09:32 AM
defiancy's Avatar
You could do that, just make sure you use an inline fuse when you wire up the windows.
But honestly you could probably just run wiring from the fuse box just as easy as from the battery. But whatever is easier for you.
Old 05-02-2007, 08:08 PM
ok ,so i checked all the fuses and they all have power , now i have no idea what to do...
Old 05-02-2007, 09:37 PM
This is going to be a trial and error project, it's extremely hard to help diagnose something like this online.
95 Talon TSI AWD
97 Eclipse GST
Old 05-02-2007, 11:14 PM
defiancy's Avatar
Are you sure there is a wire running from the fuse to the doors? Best way to shoot this if you have a volt meter/multi-meter is to find the power wire on the door side plug and plug the other lead into the fuse, you should have conntinuity there if there is a wire running between the two.
Old 05-28-2007, 07:59 PM
Smile Re: Power Doors Problem
ah haa!!! i figured it out ,,,i checked all the wires by themselves to find which one gave my switch power( its the big blue one).then i just ran a fused wire from the battery to the switch and now it controls both sides windows and locks... took long enough though.
