Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-30-2007, 05:17 PM
jase386 jase386 is offline
Send a message via AIM to jase386
experts HELP : spark knock
85 caprice with 305.
spark knocks just before a downshift after a turn, or when starting to pull a hill.
running premium gas, new EGR, timing is perfect according to mechanic. New plugs, rotor, wires, cap, have had distributor control module tested, its good.
any ideas on what to try now? would leave it at the mechanic, but out of $$$
thanks for any help
Old 04-30-2007, 08:15 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: experts HELP : spark knock
Knock sensor, ESC module, or wiring between them. Have you checked all of these?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-30-2007, 10:52 PM
where are the knock sensor, and ESC module located?
i would be glad to check them, since now i know they exist. this is my friends car and i dont know how much more whining i can stand
Old 04-30-2007, 11:24 PM
silicon212's Avatar
Confoundingly Lucid
Knock sensor is on the passenger side of the engine block, at the block water jacket drain, in the middle of the engine above the oil pan. It has a single wire attaching it, running frontward toward the computer wiring harness behind the alternator.
The ESC module is located in a bracket on the passenger inner fender that also contains the BARO sensor. It has 5 wires on it, one of which ultimately goes to the knock sensor (that wire I talk about above).
