Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 04-30-2007, 12:29 PM
281_Stang 281_Stang is offline
Sway Bar Improvments
I have a 2002 GT and I am going to get lowering springs and was wondering wile i was down there i would install a new sway bar also. Is the sway bar really going to make much of a difference in the handleing or is it not worth it?
Old 04-30-2007, 01:12 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Sway Bar Improvments
I am not an expert with that model. It normally a good thing, but its not always the case. There is a science to suspension, and it changes from car to car. If no one on here can help, go to corner carvers, of a modual forum that road races.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-30-2007, 08:07 PM
Also with the lowering springs, do they make the front wheels angle inward out of alignment, and if that is the case, is that what a caster/camber plate is for, to make them able to be aligned again? and is the c/c plate a must or just a good idea?
Old 05-02-2007, 09:43 AM
351wStang's Avatar
351wStang 351wStang is offline
Caster camber plates where a must once I converted to coil-overs on the front of my car. That would be another good question for a corner carver forum.
1969 Cougar
357w & TKO - 475hp
Old 05-11-2007, 04:24 AM
zagrot zagrot is offline
Send a message via Yahoo to zagrot
effective spring rate = sring rate + swaybar spring rate. watch out for bump steer when lowering, this can be rectified by repositioning your steering rack with offset bushings.
Old 05-11-2007, 06:02 AM
der, forgot to mention this fudemental bit about sway bars: they actualy reduce traction on the end that they are placed, ie: front sway bars reduce front end tractoin leading to understeer, and rear swaybars reduce rear traction leading to oversteer. it reduces to a matter of what tendancys your car is exibiting and how you want to correct it. basically your selected spring rates (front and rear) should get really close to neutral steer, and the sway bars are the fine tuning.
hope this helps
