Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-30-2007, 11:40 AM
rod2004 rod2004 is offline
PCV Valve: clean or replace?
Clean or replace PCV Valve?
If clean, then brake cleaner or carb cleaner is better?
2004 rodeo 3.2L 2WD
AISIN AT
http://www.isuzufaq.com/
http://forum.planetisuzoo.com/
http://isuzuforums.com/
Old 04-30-2007, 01:44 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: PCV Valve: clean or replace?
I'd just replace it, it's not that expensive. Make sure you get an OEM part though. Aftermarket may not work as well.
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 04-30-2007, 03:27 PM
Ramblin Fever Ramblin Fever is offline
Yep, replace it, with OEM. Then, every other oil change, clean it up with air intake cleaner (O2 safe); but, still replace it every year - they do wear out.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 04-30-2007, 06:10 PM
would brake cleaner or carb cleaner work?
I have a spray bottle of those 2 lying around.
2004 rodeo 3.2L 2WD
AISIN AT
Old 04-30-2007, 10:46 PM
marcre's Avatar
don't use brake cleaner. The carb cleaner is the one you want. I'd just go out and get a new one. I'd usually spray mine off once or twice a year. Probably can't hurt doing it more often. In the three years I had my Rodeo, I replaced the PCV valve twice. May have been over-kill, but not too expensive either. Main thing is when you shake the valve you should hear the thing rattle on the inside. If you hear it it's still good.
My Rodeo
Old 04-30-2007, 11:03 PM
If your's is the original one, at 3yrs of age, I would be replacing it - it's only like $5-7 or so.
1997 3.2L V6 Rodeo
Old 04-30-2007, 11:18 PM
Thanks guys for all your inputs.
I would buy a new one for sure.
I asked around just out of curiosity and learn about this stuff.
I asked the dealer and it cost around $16 for a pcv valve for my car.
I'll go get it this weekend and replace it just because ...
oh, FYI, It's orginal. 3 years long. shaked and still rattle.
Just got my fuel filter replaced so why not pcv valve too huh?
2004 rodeo 3.2L 2WD
AISIN AT
Old 04-30-2007, 11:34 PM
marcre's Avatar
yea, good idea replacing it. May still be good, but you never know. $16 is a cheap insurance.
My Rodeo
Old 05-01-2007, 07:18 AM
2000izusu 2000izusu is offline
i keep a new one on mine because the 98+ 3.2's already burn oil. i don't need more oil missing between changes! mike
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 05-01-2007, 07:34 AM
surferfletch surferfletch is offline
Hmm. 160K+ on mine. Maybe I'll swap it. That'll kill 5 more minutes of the 2 weeks I have off...
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 05-01-2007, 10:08 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Until the rubber grommet falls apart and drops into the valve cover. Then you spend the rest of the day tearing things apart to clean it out. LOL kidding. Thats just my luck though.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 05-01-2007, 10:55 AM
Been there done that! I looked for the grommet as soon as I finished finding the PVC.
Old 05-01-2007, 06:15 PM
I just cleaned mine out with some intake cleaner. Is this a true PCV valve? I can blow through either side without flow impeded. It's acting like a simple crankcase breather, an elbow without any check to backflow. It jiggles when I shake it, and I can see a little spring in the bottom...
I guess it'll be answered when I get the new one...
Old 05-01-2007, 07:07 PM
I believe from my limited knowledge that pcv valve is a one-way street device.
You can blow freely thru the inlet but not the outlet.
If both feels the same then replacement is needed.
2004 rodeo 3.2L 2WD
AISIN AT
Old 05-01-2007, 07:09 PM
oh, for my car, the pcv valve looks like a giant screw that you screw into the valve cover on the right bank ( standing in front of engine ).
I think the older rodeos use the elbow type.
2004 rodeo 3.2L 2WD
AISIN AT
