Old 10-17-2002, 07:04 PM
D16 V-TEC's Avatar
D16 V-TEC D16 V-TEC is offline
Send a message via ICQ to D16 V-TEC Send a message via AIM to D16 V-TEC
question regarding body panels
hey guys, i was wondering if the body panels, specifically the rear fender, are welded on or simply bolted on somehow? i am going to get a new panel and want to know if i need to have a shop do the work of if i can do it myself. TIA
Perky Nana Boy!
I am Jack's biting sarcasm.
1990 Honda CRX Si
I poach Pandas and pimp Sheep!
Old 10-17-2002, 07:58 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
well the front fenders are bolted on, but the rear quater panel is welded on cause its attached from behind the door all the way back and up to the roof.... if you need to replace the rear quarter panel i highly suggest taking it to a body shop. I work in a a body shop and have seen how they do this procedure. It quite complex for a 'do it yourself' job.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 10-18-2002, 11:56 AM
kaytec4door kaytec4door is offline
well the fronts are bolted on and the rears are welded. and they are not the cheapest thing either. do not do the rear panel by yourself.
:smoker2:kaytec4door:smoker2:
mods done: AEM cold air intake,
ractive racing cat,
ractive axel back exhaust,
NGK plugs,
nuespeed cross-drilled rotors,
EBC the green stuff pads,
projecter headlights,
clear corners,
carbon fiber tails,
Z3 fenders,
adjustable coilovers,
Konig flatline rims with dunlop fm901 (17*7),
full complete sound system with two 10'' subs,
kenwood 600w amp,
punch cap,
pionner speakers all the way around,
full custom interior paint job,
reverse indiglo guages,
aluminum gauge bezel,
d16a6 head swap polished,
4-2-1 ceramic coated header,
:finger4: proud member of team kay tec:finger4:
Old 10-18-2002, 11:57 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
nope it's not a bolt on piece like the front fender. no disrespect but, since you asked how to do it, i assume you don't have much experience with body work. that kind of repair really should be done by a body shop.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
