Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 10-17-2002, 07:01 PM
velvett velvett is offline
Send a message via AIM to velvett
Question 98 - 328i / Maintenance & repairs
HI!
What sort of clues would I look for or listen for when my car would be in need of the following:
1 - New brake pads AND rotors.
(don't you usually hear a grinding sort of noise when the rotors are in need of replacement?)
2 - New secondary air pump value
(is there a kind of gurgling noise?)
3 - New thermostat
(would in gauge inside of the car show anything unusual?)
Thanks in advance.
Old 10-18-2002, 03:22 AM
Rossco Rossco is offline
The brake light should light up on the dash when the pads are wearing out. They have a wire on them that grounds to the disc's when the pads get thin.
The thermostat should hopefully not give you any problems. If it does it will generally do one of two things, either stick open - engine will run cold - take a long time to heat up, or stick closed - the engine will overheat - not good.
Cheers
Rossco
1996 E36 320i
Old 10-23-2002, 01:23 AM
mini///m3 mini///m3 is offline
Id say thats about $600.00 in parts if there genuine BMW. Then theres labor. Could be a few hundred more.
