Old 04-30-2007, 09:46 AM
philburn philburn is offline
Overdrive not working
2001 intrigue 100k miles.
All of a sudden, my overdrive is not working. I noticed it when the tac was showing about 3500rpm as opposed to around 2100 when at 70 mph. I have had the fluid checked regularly but have never had a flush/service. Anyone have any suggestions?
Thanks
Old 04-30-2007, 10:53 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Overdrive not working
Any Service Engine Soon or Service Vehicle Soon lights?
Check the fluid level, this can simply happen because of being low on fluid.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 04-30-2007, 08:45 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
the splines on the shaft for overdrive may have stripped out, you might be needing a trans repair
2003 Pontiac Grand Prix 3.8 Litre V6
ASE Certified Master Tech
Old 04-30-2007, 08:54 PM
No service engine lights have been on. I checked the fluid level the way the owners manual prescribed and it might have been a "bit" low but certainly in the hashed marks of the dipstick.
Old 04-30-2007, 10:24 PM
notimprezed notimprezed is offline
I had the OD go out in my 98 @ 160,000. Had to suck it up and put a remaned one in to fix it. $$$ Its time to decide if you want to put $2000 into your car or just trade and get something else.
Old 04-30-2007, 10:39 PM
phewop118 phewop118 is offline
Occasionally when the transmission is cold mine refuses to shift into overdrive. All I do is push the gas until it goes down into 2nd and let off the gas. It then will upshift into od.
Old 05-01-2007, 11:07 AM
GMIredneck GMIredneck is offline
I am assuming that because yours is a '98 you have the 3.8L and the 4T60-E transmission. My wife had a similar problem on the same tranny. After running the car with "slightly" low fluid for probably 3 months, the car stopped shifting into overdrive. It eventually got worse so that it had trouble shifting out of gears. Sometimes things would work fine, but not ususally. The problem was later diagnosed as a corroded check valve ball. The solution was a rebuid that cost around $500 US. I hope yours is a simpler problem.
GMIredneck - 2000 Intrigue GL mods- Slotted & Dimpled front rotors, Kenwood Stereo & Speakers
Old 05-01-2007, 12:45 PM
LittleHoov's Avatar
Not that this really has anything to do with the problem, but the transmission in question isnt a 4T60-E its a 4T65-E, the latter started being used in 97.
Old 05-02-2007, 10:26 AM
Thanks for the clarification LittleHoov. Phewop118 disregard my previous reply.
Old 05-08-2007, 12:03 PM
In case anyone is wondering.....I had to have tranny rebuilt.
Old 05-08-2007, 12:25 PM
alejmr alejmr is offline
HI! this is my first post.... and one annoying question: how much did you pay for your rebuilt and is this a recurrent problem on the intrigues? I've 98 3.8
Old 05-08-2007, 04:02 PM
It was $2100
