Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 04-30-2007, 08:25 AM
FredA FredA is offline
Battery compartment sensor ?
I have a 98 Neon (SOHC w/air). There is some kind of sensor inside the battery compartment, that enters from below the compartment. It is held in place witha larde hex nut. Unfortunately, I broke this sensor while removing the battery compartment, now I need to get a new one, but I don't exactally know what it does, or what it's called. Can someone shed some light for me ?
Thanks !
Old 04-30-2007, 01:06 PM
denisond3 denisond3 is offline
Re: Battery compartment sensor ?
Its called the 'battery temperature sensor'. If your auto parts place tells you its a dealer item and it turns out to be expensive - you can probably find one at any junkyard having a Neon. Since lead-acid batteries are less efficient in colder weather, the charging system has to charge the battery at a higher rate in winter, and this sensor is what does that.
Old 05-02-2007, 07:13 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
The sensor on the neon doesn't do anything though, AFAIK.
2003 Dodge SRT-4
Old 05-10-2007, 10:51 AM
A97 A97 is offline
I just replaced mine because it went bad my check engine light and battery light were on. Auto zone wanted $21 for it I bought it at the dealer for $15. Didn`t have the nut either I just put a zip tie on it to keep it from falling down and banging around.
