Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 04-30-2007, 12:31 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
amp anygood? although i bought it already
http://cgi.ebay.com/ws/eBayISAPI.dll...0323&rd=1&rd=1
any good just running 1 12 inch audiophonics 1600watt sub...???
Old 04-30-2007, 11:20 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: amp anygood? although i bought it already
The amp is 360 watts RMS at 2 ohms, so you will be underpowering that sub. Max on that amp is half the max on your sub. I'm guessing the RMS of your sub is somewhere around 800...so that amp falls short. Shoulda went a little bigger, you can always go bigger and if it's too loud just turn the amp down, but now your stuck with a low power amp that dosn't have the capability to run that sub at the power level it was designed for.
I once heard from a car audio guru that it is better to apply more watts to the sub than it is designed for and keep it on low than to underpower it and crank the amp as high as it goes, only to fall short. But I could be getting that screwed up, it's been awhile...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-30-2007, 06:29 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I've also heard that it's actually better for a sub to slightly over-power it than to underpower it...I don't know why, that's just what I was told.
95 Talon TSI AWD
97 Eclipse GST
Old 05-01-2007, 10:06 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Thats only a 360 watt amp. l_eclipse_l said something about the max being half the max of the sub. Yea on the box it says 800 max, but max means nothing. Max is made up BS to sell more amps. That amp will only do 360. Yea I would have went bigger but still it should sound decent. It won't be loud but it will be something to listen to.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-01-2007, 05:22 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Is that sub 2 or 4 ohm, single or dual voice coils? These are other factors you need to look into when choosing an amp. The one you bought is not stable at 1ohm so if your sub is dual 2ohm voice coil you will have to to run the amp at 4ohms and you will be getting even less power.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 06-27-2007, 12:55 PM
shearphysics shearphysics is offline
ok first off its always good to underpower a sub then overpower if u overpower u will have the sub distorted at low levels other words your car will sound like u have aluminum cans in it and my guy has that same amp pushing two rockford punch 800s and it hits hard. that sub he has is probly like 800 watts rms.if you need a bigger amp send me a pm i have a 1200 watt mono
Old 06-27-2007, 04:51 PM
Holset powered 420a
Dude this thread is about 2 months old.
98 Eclipse GS Turbo
2001 BMW 325i - DD
