Old 04-29-2007, 11:19 PM
kcook6355 kcook6355 is offline
Question More Power
I just Found out my 95 ford F250 needs a new motor and trans I want more than stock horsepower what should I do. what about converting to diesel I dont know need input
Old 04-30-2007, 01:15 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: More Power
being an F-250, a swap for a 7.3 PowerStroke should be pretty direct. you'll need the diesel's wiring loom and all the neccessary mounts/exaust/etc gear as well as the engine, gearbox and driveshaft. you may also need different differential(s) for the extra torque. don't forget the diesel engine may also require new heavy-duty suspension components to handle the extra weight of the engine.
all-in, you're looking at ~$3,000-$5,000 and maybe even more than that for all the neccessary stuff.
it's most definitely not an easy swap. the easist is a like-for-like swap where just replace the engine and gearbox with new units same as the originals.
if you do swap in the 7.3 and still crave more power, there are plenty of kits out there, and custom work can give huge numbers.
Seatbelts Saved My Life
