Old 10-17-2002, 05:40 PM
s1267712 s1267712 is offline
Help with rust PLEASE
well, I started attacking the rust on my rocker panel (right in front of rear wheel) today. It is a lot worse than I thought (but still not too bad). Does anyone know whay that is a bad rust spot, I kno water must get in there, but from where or what? Also, I think I am going to use some rust attacker (like naval jelly or something) then some rust converter (this is all INDSIDE the rocker panel) Then do a fiberglass patch. When that is all done, I wanna do something so it won't rust anymore, what do ya think, expanding foam, rust proofing spray? I dunno, this is the first time I have ever done body work, and I am a little lost. Someone please give me some tips
Old 10-18-2002, 07:38 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Rust
Once your car begins to rust you can't stop it. Once it's there it's there for life. You can grind it down and filler the holes with weld, bondo or fiberglass but it will come back, maybe a year maybe 6 months. As far as a rust proofing spray thee best thing to use is spray oil up in the wheels a few times a few but since you had it just deal with it alwyas going to be there.
Old 10-18-2002, 07:51 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Your supposed to grind all the rust away and then you can use the bondo with fiberglass to fill it in and then regular bondo to smooth it over. However it can come back. The real way is to cut out the metal and weld in a new piece.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 10-18-2002, 10:08 AM
CharmCity CharmCity is offline
Send a message via AIM to CharmCity
Yeah, when I got my car painted, I knocked out all the rust, and bonded it, and the rust came back about 6 monthes later.. So I think the only way to truely get rid of it is to cut out the metal and weld a new piece in...
94 Black Civic SI - some stuff
89 Red CRX - new wiring harness going in
www.extrememotorsports.com - sales - NEED PARTS? i'll hook you up.. email me..
www.imstarracing.com - tech inspector - come race next season!! lots of fun!
Old 10-18-2002, 10:20 AM
The rust comes through the back so maybe if you coated the wheel well in something, especially around the problem areas it would stop it coming back for a longer period of time.
