OBD code P0430
I'm getting OBD2 code P0430 (Catalyst Efficiency below threshhold. bank 2.)
I am thinking that this has to do with O2 sensor. Do you think I am correct on this? I am also wondering where this 02 sensor is located. Acccording OBD2 manual, this is a engine bank 2 O2 sensor. But there are two O2 sensors on a cat on that bank; one in the front of the cat and one in the behind. Which O2 sensor do you think I should change? |
Re: OBD code P0430
it sounds like you have a bad catalyst. if it was the 02 sensor it will tell you bank 1 or 2 and upstream or downstream. so id look at the catalytic converter
Re: OBD code P0430
According to the factory service manual, the following are the potential causes of a P0430
