Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 04-29-2007, 08:44 PM
pambenahwy pambenahwy is offline
Temperature Gauge
Hi
I have Dodge Neon 1998. I have a problem with temperature guage. The needle does not move even after engine start.
Can anyone please help me with this problem ?
Thank you
Naveed Zaki
Old 05-01-2007, 11:46 AM
denisond3 denisond3 is offline
Re: Temperature Gauge
The most common problem with the gauges seems to be bad solder joints where the connectors behind the instrument cluster mount to the circuit board. This is a problem often seen, and not too hard to fix; if you have a phillips screwdriver, a set of the lilttle torx style wrenches, and own or are willing to buy a small soldering iron. On mine the fuel gauge and the speedometer worked when they felt like it - about half the time. The link below has the details:
http://www.myneonspeed.com/howto/how...clusterfix.htm
This fixed the gauges on our Neon. If you damage the cluster, any cluster from a 96 to 99 Neon from a junkyard should work, after soldering Its connectors. They have prices (here in Texas) varying from $20 to $75 for a used instrument cluster. And they are easy to remove from the car.
Also available on ebay.com now and then; but you still will need to solder the connectors!
Let us know if this doesnt fix the problem.
Old 05-02-2007, 07:34 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
^^^That isnt necessarily for the temp gauge though.
For the temp gauge problem, you need to look at your cooling system. Are the fans kicking on when they are supposed to?
2003 Dodge SRT-4
Old 05-03-2007, 06:40 PM
Bear Bear is offline
Two possibilities:
1. a thermostat that is failed in the wide open position.
2. A faulty coolant temperature sensor ( in cylinder head on SOHC, or next the thermostat housing on the DOHC).
Old 05-03-2007, 07:31 PM
Originally Posted by Bear
Two possibilities:
On a SOHC, its not in the head, persay, it's next to the camshaft position sensor.
2003 Dodge SRT-4
