Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-29-2007, 05:28 PM
blutahoe blutahoe is offline
Exclamation Brake light problems
My brake lights are not working, I've changed the brake light switch, also the brake lights, checked fuses, hazard lights work, tail lights work....Any advice on how to solve this problem.
Old 04-29-2007, 06:35 PM
maxwedge maxwedge is offline
A990 racer
Re: Brake light problems
Changed a lot of parts but have you checked what is actually wrong, current in and out of the stop lite sw., current from the switch up to the signal switch and out? Please get used to posting the year also.
Old 04-29-2007, 08:38 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
If you have a trailer brake setup, check the connector on the bottom of your rear bumper. Open up the cap and smell in there to see if its shorted out. Also try disconnecting it.
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 05-03-2007, 01:26 PM
glenncof glenncof is offline
Fuse would blow if a short.
Get schematic and volt meter to trace the circuit.
Off the top of my head;
battery* > fuse > switch > lamps > ground
* may be switched on with ignition but not likely ( I think brake light are constant feed on most american.)
Diagnosis first then replace parts.
