95 Riviera Window Problem
Hey everyone,
I have a 95 Riviera and I used the power window switch on the passenger side to put the window down and it worked fine. Then neither sides worked and neither will go up or down. On the driver side it sounds like a clicking noise when I try to put the window down, and nothing is heard on the passenger side when I try to put that one up. The Riviera book says the fuse is under the back seat and I checked it out, but the fuse is for power windows and sunroof, and the sunroof works fine. Please help, I don't know what it could be. |
Re: 95 Riviera Window Problem
could still be a fuse. check all of them with a ohm meter or fuse tester. if not then maybe the driver switch has gone bad and the switch is stuck in the down position for the passenger side.
dose sound like fuse...but look when you open door theres wires running threw the door up front so see if 1 or 2 wires are not bare threw the rubber boot up front when you have door all the way open you can see the rubber boot where it's rapped with wiring going threw it to your door..good luck....
I had the same problem and it was a broken wire in the rubber boot between the door and body.
Click here Thread closed.
