Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-29-2007, 02:25 PM
Fit4Demolition Fit4Demolition is offline
Send a message via AIM to Fit4Demolition
'86 Trans Am - Numerous problems
ok, so theres that speedometer problem ive been having, which i can fix easily. i tried to fix that last night but more and more problems arose. first i broke the threads on the speedometer gears. i didnt know they were plastic. so i have to get new speedometer gears down by the transmission. but thats not really a problem.
but the real problem is the fact that my car can't go faster than 20 mph because the car bogs down and almost stalls when the rpms get up to 1500. it cant accelerate past that. im thinking it is probably related to the speedometer problem as the computer is fucked up but worst case scenario is the transmission is gone or the clutch is screwed up. when the problem got really bad i tried going through the gears manually (its an auto tranny btw) by starting off in first then pushing the shifter into second then third. but each time when the rpms got to 1500 it would start to bog down again. i think now that it is probably the carburetor that is screwed up.
any suggestions on what could be happening?
Old 04-29-2007, 09:08 PM
Morley Morley is offline
Re: '86 Trans Am - Numerous problems
replace the fuel filter for starters. There is usually one that sits inside the carb (rochester), remove the fuel feed line from the carb, then remove that fitting from the carb, the filter is in there. Most people don't know about that little filter and it never gets changed.
Old 04-30-2007, 10:42 PM
that was actually one of the first things i tried to fix. i changed the fuel filter about a month ago and it didnt help anything. when the car really got bad last week i actually took the fuel filter off to make sure the filter wasnt clogged. i guess the next step would be to change the fuel like since it got crimped up a little bit when i first changed the fuel filter. but it wasnt running bad when it first happened, it started going bad later on. i have a good feeling that the carbeurator is messed up, either the accelerator pump or the choke. if the carbeurator is messed up then i will just have to get it rebuilt. once i get my bike though, if the problem is with the carbeurator then i will probably just get an edelbrock carb and new manifold.
any other suggestions Morley? seems like you are the resident mechanic here.
Old 05-01-2007, 02:33 AM
New /rebuilt carb seems to the the next step. Either your float isn't letting in enough fuel or it is letting in too much.
Be aware that if you have the stock carb, it is computer controlled and if you replace it with a non computer controlled carb, you are going to have problems with the ECM. For the cost of a rebuilt Rochester computer controlled carb you could almost convert to TPI.
Old 05-01-2007, 11:42 AM
yeah i really wish my carb wasnt computer controlled. can you explain a little more about that last part there, about the Rochester thing?
Old 05-03-2007, 12:23 PM
i have to take out the speedometer gears to find out what color they are and how many teeth it has for a dealership to order the part. any advice on how to get it out? there isnt a good spot to pry it off with, and pieces of it just chip off if i try to dig in and get leverage. any advice?
Old 05-03-2007, 11:05 PM
ACK! Don't pry it off! There is a Y shaped retainer holding the speedo gear cover onto the transmission and the cover has an O ring to seal it in the trans. Remove the Y retainer with the cable still screwed onto the retainer. Gently rock and pull on the cable housing until the speedo gear cover comes off. Now you should be able to remove the gear with your fingers.
Old 05-05-2007, 04:10 PM
haha, i didnt have the retainer still on there when i was trying to get it off. and i couldnt have the cable still screwed onto the cover because the threads broke off. i got it off this morning though. it was actually pretty simple. i was trying to pull it out but couldnt get leverage. so i put vice grips on it and twisted and it came right off, and then about a quart of tranny fluid poured out all over me. but at least now i know i dont need the gear, i just need the cover.
now i just need to know what is going on with the carb and my car will be back on the road.
Old 05-11-2007, 10:37 AM
iroc343 iroc343 is offline
Don't know your exact situation, but on my brothers 82 firebird (305 rochester 4bbl) we turned the air cleaner lid over to create a gap between the lid and the base for more air and the thing would run fine until you got on it, then it would about quit and all kinds of black smoke would pour out the exhaust. Turns out the lid in it's upside down state was so close to the bowl vent it created a siphon drawing raw fuel down the venturis. Flipped the lid back over and problem solved. Took awhile to figure that one out.
Old 05-12-2007, 11:14 AM
Blue Bowtie's Avatar
Registered Offender
Completely rebuilding an E4ME should cost about $30 - $40 if you get a new float. If you need a new TPS or MC solenoid, the cost will increment accordingly.
Changing backward to a non-feedback carb is just lazy, and will cost you both power and fuel mileage. Properly adjusted, the E4ME will meter fuel to meet even current emission standards, provide the daily driveabilty of an EFI system, and feed almost 800 SCFM with plenty of power enrichment. You'd be hard-pressed to find another carburetor which can claim that. The problem is that the majority of people get challenged when it comes to the "properly adjusted" part, despite volume which have been printed on the subject.
Old 05-14-2007, 05:45 PM
well thats good news. i got a new speedo gear cover, where the cable threads on to because the old one broke when i was tightening it. only 2 bucks from a junk yard, only i had to sand down the spindle of the speedo gear and bore out the cover a little. it was pretty hard getting the cover back in place. but as far as i know its in there right, i'll find out later i guess. tonight im going out to get more tranny fluid and im going to adjust the top end of the speedo cable, i cut it too long and crimped the end on. hopefully then the speedometer will work right and after i disconnect the battery for a while i hope the mixture problem was computer related instead of the carb being screwed up.
Old 05-15-2007, 10:58 PM
next thing to fix on my car is the carbeurator. idling it is fine, but when i go to accelerate the rpms drop and the car is barely running, like no air is getting in. then when i let off the pedal rpms jump back to normal. any idea on what the problem is?
Old 05-16-2007, 02:28 AM
Accelerator pump is the first thing that comes to mind.
Old 05-16-2007, 10:16 AM
to fix that would basically take a rebuild right? not a quick fix?
i tried running my car on the road just to see if i can get a better description of what is going on. first when i start the car it seems like everything is working fine. i took off the air cleaner assembly so i could see the carb, and when i stepped on the gas lightly the choke would open up a little, and if i stepped on the gas more the big flaps opened and it sounded like everything was running fine. in park everything is working ok, but when i go in reverse to get it out of the garage thats when the problem always arises. i step on the gas lightly and its ok but once those big flaps open the car seems like its shutting off. the longer i keep my foot on the gas the lower the rpms go, and when i let off the gas it jumps back to life. the only way i can accelerate is to tap the gas like crazy. so when i get the car back in the garage and put it in park, the problem is still there which i find strange because before when it was in park it was fine. is this a better description to base a diagnosis off of?
oh, but the speedometer is finally fixed, but now the tach, the volt meter, and the fuel gauge are fucked up. go figure. and the choke light is always on, but im not sure if that is because the choke is messed up or because the gauges are messed up.
i just called a mechanic and he said that it doesnt necessarily sound like the accelerator pump and it might just be the fuel line is clogged up or the fuel pump is going bad. is there any validity to his diagnosis?
Old 05-16-2007, 11:25 AM
If the choke light is always on and the choke butterflys are closed after the car is warmed up..the choke is FUBAR.
The accelerator pump can be replaced without a complete rebuild.
