A/C Blower
I have a 92 Astro and the blower will not work in low and medium speeds. Can someone help? |
Re: A/C Blower
Welcome to AF.
The leading cause of no lower blower speeds is the blower motor resister block. Look on the ac/heater core housing for it and see if it is plugged in and wires good. Then get a test light and see if voltage is going to and threw it.
Re: A/C Blower
The blower resistor needs replacement. It is located under the hood, and mounts with two screws to the evaporator housing near the blower motor. There are 5 wires connected to it. Most auto parts stores stock them.
Re: A/C Blower
Mine ('97) had the lower speeds quit too.
I removed the resistor block, and found that the printed "wire" on the board had been eaten by the sealant. I soldered in a replacement wire. (I could see where the printed foil was) All is well. |
Re: A/C Blower
in my 99 i replaced.the block and it was only 37 bucks and it was a delco part
