Old 04-28-2007, 10:30 PM
jamesmetairie jamesmetairie is offline
wierd science question=
98 lumina,3.1 litre. weeks ago, my shady tree mechanic put the wrong "o ring" where the distributor was. yes,it,s still leaking .he already tried to replace it . No Luck ! now he says it,ll be the whole manifold gasket job to get to it .my question = can he degrease the area and put a healthy dose of "liquid steel " all over it. should that do it if it ain,t under pressure?
Old 04-29-2007, 06:30 AM
john51md john51md is offline
Re: wierd science question=
Question... if he put wrong gaskest on, why cant he put the right gasket on?
and why would it need intake gaskets if its the dist. gasket leaking?
On the 2.8 i had, didnt have to remove the intake to replace dist. seal. And i made one from flat sheet gasket material, and didnt bother replacing the O ring, it never leaked a drop after. I think you either misunderstood what he said, or he is indeed "shady"
Old 04-29-2007, 05:53 PM
it is my understanding that for him to be able to get to the "o ring" he needs to disassemble the manifold right on down. he tried unsuccessfully to replace the "o ring " already . my local chevy dealer sold me the wrong "o ring" when i was having the lower intake manifold gasket replaced . we used a "fel-pro " gasket kit. the mechanic said he had some "o rings " for auto zone? now i have oil leaking on the car port floor daily.
Old 05-01-2007, 07:39 AM
I dunno, all i can say is my 89 2.8 didnt need intake touched to pull that dist. piece and replace seal. If i remember right, pulled the throttle body and had clearance for it to come out easily.
And as i said, i didnt replace the O ring at all, i just used a flat gasket like other distrubuters had, and its never leaked.
Old 05-01-2007, 08:43 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
All he needs to do is remove the throttle body to change that o-ring. Since he screwed it up, it's his responsibility to fix it. He shouldn't charge you a dime. If he knew what he was doing, he'd have also installed a small block Chevy paper distributor gasket in there to insure against future o-ring failure. If he won't fix it without charging you, you probably have no legal recourse, being he's a shade tree and not a licensed repair facility.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-02-2007, 06:20 AM
^^ what he said......
Old 05-20-2007, 03:56 PM
he finally got it right. charged me $60. and i gladly paid. no more oil on the car port floor. now if i can just firgure out why this car is only getting 16mpg in the city with the a/c on i,ll really be happy.
