Old 04-28-2007, 05:57 PM
ImaFordChick16 ImaFordChick16 is offline
1999 Taurus feels like it's slipping into neutral while driving
I bought my taurus about 2 mo's ago. The problem I'm having is that I can be driving it and all of a sudden it feels like I've put it in Neutral. I've also noticed it only does this when my speedometer gets stuck on zero. While it's coasting I keep trying to give it gas and finally the speedometer gets unstuck and my car runs fine. Anyone have any idea as to what might be causing this? Also let me add that it will do this at any given time. The car doesn't have to be hot and it doesn't do it "every" time I drive it. TIA
Old 04-29-2007, 12:31 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1999 Taurus feels like it's slipping into neutral while driving
Welcome to the forum!
Sounds like you have a faulty Vehicle Speed Sensor (VSS). The PCM uses the VSS to vary solenoid pressure in the transmission as well as the adjust the shift schedule.
-Rod
Old 05-02-2007, 07:52 PM
-Rod
Thank you Rod. I will have someone check it out.
