Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-28-2007, 09:24 AM
geohauss geohauss is offline
199 ford ranger overheating
I have a 1999 Ranger that is overheating during the idle. If I rev the engine, it will cool down. A bit of background: Back in January the fitting that the heat sensor plugs into (which screws into the coolant housing) rusted out. This got rust in my coolant system, and I had it flushed for the second time on Thursday (26APR07), and it is still heating up during idle.
Does anyone have a clue as to what might be causing this? What can I do?
I appreciate any help. Thanks.
Old 05-03-2007, 09:45 PM
98XLTKid 98XLTKid is offline
Re: 199 ford ranger overheating
i don't know if this is the problem but have you tried replacing the thermostate?
Old 05-04-2007, 05:46 AM
manlystanley manlystanley is offline
Check your upper radiator hose to see if its hard or not. If not, it's probably your thermostat or water pump.
Best Regards,
Stan
1995 Plymoth Grand Voyager; 1998 Volvo S90, 2000 Ford Ranger, 2002 Dodge Grand Caravan.
Old 05-16-2007, 08:54 PM
Fredoe37 Fredoe37 is offline
Im not sure if that model is still using the fan clutch system or not...if it is try spinning the fan when the engine is off and heated up...if it spins freely then you most likely have a bad fan clutch.
Old 05-19-2007, 10:36 AM
DonSor DonSor is offline
I assume that the temperature gauge is giving the right indication. You stated that the engine gets too hot while idling but cools down when you rev the engine up. How does it do when driving the vehicle? I also have a 99 4.0L Ranger. The fan clutch has a "viscuous pump" and a spring-like temperature sensor. When you first start the vehicle (hot or cold engine) the fan runs at the same speed as the pump. The viscuous fluid in the clutch builds up and disengages the clutch and the fan slows down. From then on the fan clutch responds to the temperature sensed by the spring. The stat is easy to check. I'm suspecting it's the fan clutch. if you do decide to replace it check the pump thoroughly because sometimes a bad pump could cause the clutch to go bad and vice versa.
