Old 04-28-2007, 08:01 AM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
Engine & Trans identification
I need to find the year of my engine since it had been swapped when I got the car. Are the numbers located the same place as older blocks? What's the best way to get to them?
On the transmission, what are the gear ratios? I have the ratios for a close ratio and a wide ratio but don't know which I have. Do the numbers cast into the trans case mean anything? It has 13-86-212-901-11 (may be an H).
Thanks,
Rob
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 04-29-2007, 09:49 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Engine & Trans identification
here u go.
http://www.mortec.com/location.htm
click on V-8 casting numbers to identify your block.
I would suggest placing aluminum foil over the casting number and rubbing it so that you imprint the number in the foil.... or using a digital camera and flash to get the number.
sorry.... dont know about ID'ing tranmissions. which tranny is it anyway? T56?
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 04-29-2007, 01:56 PM
rob67gmc's Avatar
Thanks for the reply. I've been building older sbc's for years and the mortec site has always been helpful. I know very little about the newer engines and thought this might be an LT1 but I just found out LT1's don't have a traditional distributor. Is this correct? If so, I don't have an LT1.
Yes, the trans is a T-56. I've got a friend that used to build tranny's and he's looking up the numbers for me. Hoping someone here would also know just to be sure.
Thanks,
Rob
K&N filter
Richmond 3.73 gears
KYB struts & shocks
