Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Commodore/VS/VT/VX
Old 04-28-2007, 03:09 AM
matty8585 matty8585 is offline
vs 5 litre ute trouble
i have just recently bought my vs 5.0 mauual ute im getting a clunk when changing gears ,when i put foot on and off the clutch (reverse pretty bad) and also ,when i tap the throtle at any speed .is it diff ,gear box, tail shaft or anything else. Has any one got any ideas i would be greatly thakful.
Old 04-29-2007, 05:50 PM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: vs 5 litre ute trouble
Diff pinion gears are worn, very common is the V8 utes as they either have no weight in the back or too much weight(overloaded)
Also check the tailshaft universal joints are not worn.
Actually, get the uni joints replaced first as they are cheaper and if the diff gears are stuffed, the uni joints are probably stuffed as well. So if you replace the uni joints and the noise is still there, then a new diff can be fitted and know that the uni joints won't let go a few weeks later
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
