Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-27-2007, 07:05 PM
mark.jones1 mark.jones1 is offline
96 Camero Brake Lite
I have a 96 Camero and the Brake Warning Lite stays on. The car is a 5 speed and I think it might be the Switch for the Park Brake. Is the Park Brake Switch located in the console? Is there anything else I can check?
Old 04-28-2007, 11:06 AM
jlynx jlynx is offline
Re: 96 Camero Brake Lite
Is your brake fluid normal level? Does your brake pedel sink to the floor slowly when you push on it and hold it for a few seconds? I had the same problem when my brake light switch kept staying on, I found out that I had air in the brake system because my master cylinder was leaking and was always running out of fluid. Another way you can check is looking around the master cylinder for brake fluid leaking, usually below it. And, while your right there you can check and see if your brake resovior sensor which is located on your brake resovior is bad. That will keep your light on also. You can also try bleeding your brakes at all 4 wheels. If that doesn't help at all, at least you know that your brakes are air free. As far as the Park Brake switch, it should be inside your console somewhere next to the lever. As far as I know it should be. Hope this helps.
Old 04-29-2007, 01:02 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
There is no sensor on the master cylinder. I've got the same problem and haven't been able to figure it out for almost a year. Done everything from bleeding the brakes, checking the parking brake switch to the changing the rear 3rd brake light bulbs.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
