Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-27-2007, 06:35 PM
Mike_EX Mike_EX is offline
2000 Montana-How Exactly Does One Replace The Serpentine Belt
Subject Says it All. I guess I'm not finding where the tensioner is or
how to get it to release the old belt. Thanks.
Old 04-27-2007, 10:54 PM
HC2000 HC2000 is offline
Registered User
Re: 2000 Montana-How Exactly Does One Replace The Serpentine Belt
Hi, My 99' is as follows:
Remove the long black plastic windshield wiper motor cover for better access.
Look for the lowest and most rearward positioned pulley.
There is a slot which accepts a 3/8 inch rachet or pull handle.
This is the tensioning pulley.
Your model is probably the same as this or similar.
Regards, HC2000
Old 04-29-2007, 07:42 AM
hufhouse's Avatar
hufhouse hufhouse is offline
The pulley is connected to a triangular pivot. You literally stick the square part of a 3/8" ratchet into a square hole on the pulley. Pull the ratchet back toward you to release the tension.
Good luck. It's helpful to have a third arm protruding from your chest to get the belt back on. Unfortunately, I don't have one of those.
Come to think of it, that's probably best.
Old 04-30-2007, 12:17 PM
cdru's Avatar
cdru cdru is offline
In other words, it's the pulley between the crank pully and the power steering pump pulley.
Vinyl adds horsepower, right?
