Old 04-27-2007, 04:43 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
A true DSM story... (sad)
Well my car was down for awhile with a few problems with the new built head. Found out the reason my coolant was pushing out of the overflow bottle was not because of my new headgasket install but because of a bad water pump seal. So I had a new waterpump installed along with a few other things.
Well I got my car back yesterday. I had the car for about 4 hours. Went for a test drive down a local interstate. Did a pull or two then ROD KNOCK! Yes less than 4 hours after getting my car from the garage all refreshened up and it takes a shit again. I am thinking that I may have overshot the hp rating of the stock 7 bolt bottom end a little bit. So my car sits at Extreme Motorsports in MD awaiting a forged bottom end install.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 04-27-2007, 04:58 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: A true DSM story... (sad)
That sucks. Could be worse I guess.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-27-2007, 06:13 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Poor guy..
DSM geek
Old 04-27-2007, 06:33 PM
NateS's Avatar
Literally... won't have much if any money left after this fix. Lets hope it lasts more than 4 hours this time hahaha.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 04-27-2007, 07:07 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Damn son... need a 6 bolt?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-27-2007, 08:01 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
how much hp is ur car running on the stock bottom end.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 04-27-2007, 10:47 PM
WaFFeL WaFFeL is offline
Hey it could always be worse
Old 04-27-2007, 10:52 PM
NateS's Avatar
Actually, I'm not sure. I only had the boost at 16psi. However, I did just have a completly built head installed with a nice set of cams. I'm going to take a wild guess and say it had to be close to 380hp at the crank. On the drive home from the shop I smoked a brand new STI so thats all I have to judge from.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 04-27-2007, 10:55 PM
NateS's Avatar
Very true. My friend that was riding along when this all happened kept sayin wow your taking this pretty good. I figure hey, I'm still alive and its just a car. Plus its an excuse to fix it up with a nice forged bottom end Sometimes I just need motivation to fix things... guess thats why I own a DSM.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 05-05-2007, 06:53 PM
twistedtech twistedtech is offline
I would be willing to bet that the bottom end had a few miles on it when you did the top end. When you tighten up the top end the bottom will surley follow. I allways tell my customers that if you doing the top at least do a in frame bottom set of bearings.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
