Go Back   Automotive Forums Car Chat > Dodge > SRT4 > SRT4 Problem Diagnosis
Old 04-27-2007, 03:09 PM
fast_driving2007 fast_driving2007 is offline
I Need Some Quick Help...
everytime when i go WOT when my car hits like 3300rpms it starts to like lag or pull back.....does anybody know wat can be the problem? can it be the wastegate...its all stock just the bov and intake and motormounts....
Old 04-27-2007, 05:58 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: I Need Some Quick Help...
Probaby either boost leak, timing being pulled, bad plugs or wires...etc.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 04-27-2007, 08:39 PM
its not a boost leak for sure because i get full boost....
Old 04-27-2007, 11:16 PM
Turbodog97's Avatar
Just a Neon
Just because you get full boost doesn't mean you don't have a leak.
05 Srt4
97 Mx-5
Old 04-27-2007, 11:18 PM
but the car pulls back like crazy.....can da spark plugs really make this happen????....
Old 04-28-2007, 08:04 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
I'd take a look at your plugs and see what color they are. Also, if you have more than about 30k miles on them, replace them. If you are using anything lower than 91octane, I'm sure the knock sensor is comming into play here.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-28-2007, 09:00 AM
i think its the spark plugs..because when i bought the car it had a stage 4 turbo but they had to replace everything because of the warranty.....and i use 91 gas...
Old 04-28-2007, 09:25 AM
Turbodog97's Avatar
Just a Neon
An agp s4 kit? And they took it all off? Also, for fyi...plugs should be changed around 10k not 30(be sure to check your gapping every oil change or so).
05 Srt4
97 Mx-5
Old 04-28-2007, 10:50 AM
i dnt know if it was agp....but the turbo said garret on it or something like dat.... the car has 28,000 miles.....i dnt know if they ever changed them...but tomorrow i will be replacing them.. whats a good brand that i can put of plugs????
Old 04-28-2007, 04:13 PM
10k if you are running anything above a s1 kit. Otherwise 15-20k is fine.
Pioneer 4900mp
Orion C63 Coax rear
Old 04-29-2007, 05:48 PM
I Replaced Them Today But Its Still The Same...it Got A Lil Better..but It Still Does It....i Will Replace The Plugs Tomorrow....should I Buy The Coil Pack Too?????
Old 04-29-2007, 08:03 PM
i just changed the plug wires also.....than i drove it again to see if it was good but nope still the same.....than i heard a pop in the engine.....can it be that the timing aint right????
Old 04-29-2007, 09:47 PM
Do this, find your throttle body which is down low between the engine and radiator. Find the TPS harness which plugs into it. It should have 3 wires if I can remember right. Anyhoo, when you find it, start the car. With it idling, wiggle that harness. If the engine RPM's change even slightly you have the common TPS harness failure problem. There's a TSB on it from Dodge.
Pioneer 4900mp
Orion C63 Coax rear
Old 04-29-2007, 10:13 PM
ima take it to the dealer tomorrow...ima see what they tell me...
Old 04-30-2007, 08:24 AM
Turbodog97's Avatar
Just a Neon
Know though, that doesn't work in every situation. Mine had the tps problem and no matter what you would do with the wires nothing would change the rpms.
Have you been gapping the plugs correctly when you have been changing them? What are you gapped at? Should be around .035 or less since I'm uncertain of your mods.
05 Srt4
97 Mx-5
