Old 04-27-2007, 11:14 AM
ricstone ricstone is offline
03 power steering
ok the power steering fluid is getting extremely hot when it is driven for about 30 or so miles. the pump wines loudly when this happens. as long as it is cool the pump makes no noise. the fluid is full an dont look bad. so whats up with this thing? thanks
ric
Old 04-27-2007, 05:26 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: 03 power steering
Needs a new pump.................
Old 04-30-2007, 11:34 AM
jkeaton224's Avatar
jkeaton224 jkeaton224 is offline
I have whining when turning sharply, (fluid level fine) how do you tell if it's the pump or the rack???
Old 04-30-2007, 04:55 PM
i changed the fluid an took the reservoir off an cleaned the screen out in the reservoir an now it don't get hot an is very quit. you might try that. good luck
Old 04-30-2007, 05:24 PM
MARZBX157's Avatar
MARZBX157 MARZBX157 is offline
the best way to fix this problem is to do the flush procedure outlined in this forum, just removing the res. won't remove all of the fluid within the lines.
Also, instead of using Mercon fluid I would a full synthetic like Mobil 1 ATF, it will hold up to the heat better. I also have the whining sound when I make left turns and am planning to do the flush sometime this summer. I will try to take pictures of the procedure to post them up if permited.
2000 Windstar 3.8 V6
