Old 04-27-2007, 01:36 AM
aorozco2's Avatar
aorozco2 aorozco2 is offline
difference in cranks
i wanted to know the main difference in these 2 cranks that IPSmotorsports.net have for sale.
first there is the remanufactured forged crank/bearing kit ($521.49) and there is the mitsubishi 2nd gen forgd crankshaft ($700).
new forged link
remanufactured link
the description on the remanufactured one it states that is just as good as a forged unit but without spending as much,
and the new crank states that "dont skimp on a cheap remanufactured crankshaft" so what is basically the difference in the resistance of both.
so when you come down to it how much horsepower can the new one handle compared to the remanufactured one. if any difference at all.
Wheels/brakes/Suspension:
Hawk HPS Brake Pads
R1 concepts cross drilled and slotted rotors
Megan Racing "Street Series" Coilover Kit
Adjustable control arms
adjustable toe arms
exhaust:
2.5" test pipe
2.5" cat back (angled out)
Misc.:
Short throw shifter
Soon to come:
TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc...
Old 04-27-2007, 06:55 AM
Hotshot8792 Hotshot8792 is offline
Re: difference in cranks
new forged link
remanufactured link
they're the same crankshaft. The new one is a brand new crankshaft. The remanufactured one is a crankshaft that has been used and taken off of a car (probably due to a problem such as a spun bearing) and then remanufactured, rebuilt, resurfaced . . . whatever it needed to be done to make it just like new.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 04-27-2007, 10:42 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
of course, the problem arises: has the reman crank been turned? i guess the only way to know is to measure each journal with a micrometer. but as long as you get bearings to match each journal, you should be ok, right?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-27-2007, 12:10 PM
I, personally, wouldn't use a remanned crank, but thats just me. I think a remanned crank might be good for someone rebuilding their motor in an N/A who plans on keeping it stock, otherwise i'd go with the new.
