| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Help!!!!! 95 Eagle Talon Non Turbo... Want To Convert To Turbo!!!
i have a 95 eagle talon, non turbo, just not enought power,
my buddie has a 91 eagle talon turbo, he said the turbo, wastegate, blow off, and inter cooler will work on my car,( hes got 3 parts cars, also said with a turbo timer?? id get 12 psi out of it?? has any one ever done this or could HELP ME ....??? thanks ! |
Re: Help!!!!! 95 Eagle Talon Non Turbo... Want To Convert To Turbo!!!
Ok... let me do this one...
1) Search. This has gone over many times. 2) Use the subforums 3) Those parts will work, however, you need a lot more than just that. You need the fuel mods, some way to control everything, and all the right hoses, pipes, clamps, manifold... and so on. If it's a stock wastegate... no. Stock springs aren't good enough tobe able to get down to the lower range, which means an external wastegate will be needed. 4) Engine isn't built to handle 12 psi. 8psi tops. 5psi is a little more safer. The block will have to be built in order to attain that without blowing the engine up. Then, the clutch will more than likely need to be done also as it won't be able to hold the power. There are many writeups, questions, and places to research this. It has been done many times all over the place. Very possible, however, not worth it in many peoples opinions. It will cost a lot if you plan on running high boost.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Depends on how much you want to put into it and how much of the work you can do yourself. You can buy a kit which will be pretty high, or build your own. I have about $2000 in mine so far but there has been alot of custom fabrication needed.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
well i can do all the work my self, just need a little guidance. i build mini trucks and other wacky stuff for a living, but lets get past that, also a buddie of mine has a 95 turbo, but no motor, tranny, or turbo, i was going to use the computer, lines, and the other stuff i can get off it and end up using the 91 turbo and inter cooler? im sure it would work ? lol first turbo im dealing with, also what am i looking into motor wise? pistons, rods, cams???? sorry for the stupid questions guys |
Keep the same ECU you have. The ECU out of a GSX/GST isn't going to work. Totally different setups.
Motor wise: everything. You'll need low compression pistons, some decent rods, bearings, everything. You'll have to get the block machined, honed, and taken care of. The head will have to be rebuilt too for higher boost. Low boost applications it's ok to keep stock. But if you're running over 9psi, you want to do a rebuild on that also. Machine work, valves, cams, springs... again, everything. You'll need a turbo manifold for the 420a. You should be able to find on for the 1st gen turbo, but it HAS to fit the 420a. Then you need to fabricate a downpipe possibly, get all the oil/water lines set up, and agian... all the fuel taken care of.
