Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 04-26-2007, 10:17 PM
ex_dilbert ex_dilbert is offline
Unhappy 98 misses under load
I have a 95 Regency 98 with a 3800 in it. It runs fine under idle, and at speed. However, under load (accelerating and climbing hills) it develops a miss and will occasionally backfire. It seems to run fine under cruise control. The problem also seems to be intermittent, happening more frequently when the weather is warm or after the engine has warmed up on a cold day. I have replaced the fuel filter, coil packs, plugs & wires. Anybody have any ideas what to check next?
Old 04-27-2007, 08:20 AM
maxwedge maxwedge is offline
A990 racer
Re: 98 misses under load
Welcome to AF. Was this there before the work was done? Any check engine lite issues?
Old 04-27-2007, 08:22 AM
The changes were my steps to attempt to rectify the problem. It hasn't altered the symptoms at all. No check engine lights have appeared.
Old 05-02-2007, 02:33 PM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
try getting the computer checked for codes. however it does sound to me like a valve is burned, or even a a timing issue. this would account for the backfire.
Old 05-02-2007, 03:06 PM
Jrs3800 Jrs3800 is offline
Timing issues and Burnt valves are extremely rare on a Series II L36...
I would also have the codes checked... Keep in mind that this car has an OBD2 connector under the steering column, But this is an OBD1 compliant car... You will need either a dealership or shop with a Scantool that will read the OBD1 Protocall with the OBD2 cable.... Even an Actron CP9145 or CP9150 Tool with the OBD2 cable will read the 95's...
I'm interested to see if you have any handshake codes
